I bought new bottom doors seals and they've been redesigned and I'm unsure which way they are suppose to go. The paper they gave me says, "new design-L shaped-must be mounted on door so when door is closed the L shape closes and makes a V shape." Holding it on the door it seems as though it should be mounted as an upside down L and makes an upside down V when closed. Is that correct? Thanks
Where did you get new door seals?
Do I HAVE to go to the Stealership?
Can you just get the pins that hold them on there?
Thank you for your courage.
