Hi Guys,
I put new brakes on my 2000 4700. My right rear caliper was trashed. I replaced pads, rotors and calipers. I removed the reservoir from the master cylinder and cleaned it out also. I bled the master cylinder and the brake lines/calipers however the back right does not seem to be getting any pressure. fluid is dripping. All other calipers shoot out a nice stream. What could it be? and the rear brakes do not engage if that helps
Discussion Starter · #2 ·
I should add that the right rear caliper blew out all the fluid and this is the same caliper (new now) that seems to have no pressure.
