How are you pressing the pulley onto the new pump?
The pump's shaft is tapped, 3/8-16unc. Using washers and a 3/8 bolt, press on the pulley. When the bolt bottoms out, stack up more washers or go to a shorter bolt. Dont forget to drop in that pump mounting bolt before you press on the pulley.
