Awhile ago my 89 E350 with the 7.3 IDI started getting a very stiff brake pedal...meaning both feet on the pedal and pushing as hard as my 200lb frame can to come to a stop. Lotta guys suspected brake booster took a crap...took it into the shop and had a new booster installed. 1st day brakes were better, not quite like i remembered where a slight touch would send you through the windsheild, but pedal feel was alot better.
Next day it started going south again needing ever increasing pedal effort to slow this beast down. It's now at the point i deemed it unsafe/road worthey for use, so stopped and picked up a vacuum pump for it since i was told these go bad too...though C6 tranny shifts like it should and selector valve for HVAC stuff works great though i know they dont take much for vacuum.
So, does that sound reasonable, the belt driven vacuum pump finally took a dump or is going bad? I have no shop to work on this thing so everything gets hired out to the mechanic shop or i'd diagnoise it myself, and when i say i have no time to mess with it, i dont, but this is our traveling tool bin so it's needed almost daily for work since it houses all my construction equipment, hence waiting for an opening to take it in and just nursing it until we have somethig else planned for the day.
Lemme know
If you already have the pump I would put it on. If you did not already have it I would pull the hose from the pump to the brake booster, stick your thumb over it with the engine running and see if it is drawing pretty hard. If it is a company vehicle I would be very cautious running it with a problem with the brakes - an accident and someone finding out what was going on could get expensive for the company.
Dave / Believer45
I've been the only one toting it to jobsites just for this reason, it reminds me of driving a race car that has no vacuum...brake pedal still works, just takes alot of muscle to make it happen. I do have the pump sitting in the van and we're going to drop it off tomorrow a.m. first thing, hopefully not a big ordeal to get it swapped out and hpefully brakes will return to normal since it'll have a new booster and new pump
Have you ever noticed the "brake" light come on while braking? If you did, means there is not enough vacuum to run the brakes.
There is a test method under one of the members here. cdnar.... (ack...forgot the rest of his nickname.) But basically, if you look under the hood, you should find a vacuum manifold screwed on to the firewall near the booster area. If you follow one of the hoses, it should lead back to the vacuum pump. Unhook this and see how much vacuum you have using a vacuum guage. You should have at least 21 inches at idle. If you do not, it means 1) pump is bad 2) hose is bad [leaking] The pulley is pressed on to the pump (at least on my 1990 it is).
If you do not work weekends, see if there is a shop that can work on it on a Sat. That's the only thing I can think of.
Visit my vacuum test on the photo link.........
If it is the pump you will need the proper pulley puller/installer....... free use from some AP stores.
About 1.5 hours time to test and replace the pump if yours is down below......
