So I replaced my front ball joints last September using Moog replacements with grease zerks. Yesterday I noticed the zerks on the uppers on both sides had broken off. Probably got hit by the axles u-joint as there was not much clearance at all.
Anybody have any suggestions on where I can get some very low profile replacement zerks so this does nto happen again?
It's going to suck pulling them axles again just to do this! Err!
Have a look on Google for spindle grease fittings. These are the only low profile ones I know of.....they use the needle attachment on the grease gun. I ended up going with non greasable ball joints, glad I did after reading your post. I never would have thought there would be any contact there.
Moog's intent was to put the straight fitting on the uppers, then use a sideways coupler to grease.
There are supposed to be low profile 90 degree zerks but I have never used them.
I originally used the 90's that came with the ball joints.
I installed straight zerks on Saturday and picked up a sideway adaptor fitting for my grease gun. It seems to work.
I was surprised how much side play is in the axle shaft at the u-joint. Hopefully the straight ones don't get broken off. I used some anti-sieze on the threads just in case. Laying on my back trying to extract a broken zerk is not fun. First one came out easy, second one I had to remove the knuckle.
When you had it apart, was the locking hub and inner spindle bearing in good shape? These two things are what keep the outer axle and therefore the u-joint on a relatively straight plane. I left the 90's on my upper ball joints and they're still there.
Yep, everything looked good. The bearing hubs only have about 8000 miles on them. In retrospect, I think what happened was my transfer case shift motor went bad in July. The truck was in 4WD (un-beknown to me) on the highway and when I turned off on a paved driveway, the front tires were fighting each other for traction real bad. I heard some knocking in the front end at the time. I think the axles were being torqued so bad they flexed and hit the zerks. Anyway, I feel better now knowing I have a lot more space between the zerks and the axle, and I can't garantee when I'll torque those wheels enough to flex the axles. Hopefully it will never be a problem again.
