I am in the process of putting custom made aluminum tanks on a 6.0 cooler I have. We are making the tanks out of aluminum because the new engine has a QSSB on it that will push 45 #'s of boost and I was told that the plastic just wouldn't hold up.
My question is: How thick of material do I need to use on the inlet and outlet? We were thinking of using .090" at a bare minimum. The other thought was to use a 3/16" thick and machine down the lip to accept the boot. Has anyone done this yet?
I've been told that the 7.3L plastic tanker intercooler "should" hold like 60 psi of boost??? Mine has held 40 psi so far without taking a dive yet. It could be bad info, so the aluminum tank will last longer. I would go with the 3/16 tube and machine the rest of the material off to make the ribs to hold on the boots.
