C-6 Linkage adjustment
Hows it going everyone---question on adjusting my trans linkage.It seems like it would be fairly simple,but correct me if I'm wrong. Do you loosen the adjustment bolt,find drive, then set the indicator on D,then tighten up? Seems like the simple way to do it,but I got to check with you guys first. My indicator is half in N when in drive,and I think I have some slippage. You would think if it's in drive,it would be no matter where the indictor points(off a little bit)Any help would be appreciated.
