Hello,
1) How do I tell if I have a California truck?
2) What are differnt about CA trucks?
3) What are the pro's and cons of the trucks?
Thanks,
Dylan
What year? The 97 in your sig? Or some other truck you are considering that isn't in your sig. Model year will make a difference as to equipment.
For the 1997 model year, the CA trucks will have split shot injectors (Suffix code AD), a glow plug left bank / right bank metal bar shunt off of the power stud on the relay, and a calibration in the PCM for California, that includes diagnostics for the left and right bank of glow plugs, and has a different look up tables, timing, and strategy to operate split shot injectors.
Also with have the fuel dampener on the fuel pump.
Should be able to do a vin lookup.
Hello,
It is for the 97 F350 in my sig. How would I do a Vin lookup to see find out? I have read somewhere that the Cali trucks can produce more power with an aftermarket chip / programmer because of the injectors.
The Engine Tag does say that that truck passes California Emissions requirements for the 97 model year. Is this enough of a "clue" that it is has the larger injectors, different programming ect?
Thanks,
Dylan
Using a vin decoder. Lmc has one. Probably even the ford website.
Hello,
Thanks,
Dylan
Look at the glow plug relay on top of the motor. Does it have a metal shunt bridging over the power output post that feeds the left and right banks of glow plugs separately?
