21 - 40 of 41 Posts
When my three daughters wanted to get a truck that looked like mine 2003 to pull there for horse trailer I didn’t want Them to get a 6.0 you don’t know what could go wrong, instead their friends said that they have Had lots of 7.3’s that they put on 450,000 without any trouble I agreed thought they would be better off instead of engine problems would be doing minor repairs breaks things like that so far that’s what has happened, no unison ring stuck when sitting for long periods the winter so forth,However they realize my 6.0 has all the updated stuff Remote oil cooler so forth new updated turbo which has the machine recess center housing allowing the unison ring to minimize corrosion,I actually find it amazing how those 7.3 fan clutch Can keep my Engine temperatures at a constant 200° as well as the tranny temperature very consistent in around 160°, there 7.3 is performing quite well I call it the intimidator with the big exhaust pipes, I don’t wanna come across like the 6.0 is a bad engine actually my daughters have a nice truck but there is no comparison To my updated 2006 engen with all the goodies.
A pop w/ smoke means you had fuel present that ignited. It may mean that you have an injector dumping fuel into a cylinder. I would also think that igniting that fuel would be pretty hard without compression unless you also had a failed glow plug contributing a spark. I would get it scanned for codes with a professional scan tool. When you get it running, an uncompensated cylinder contribution test might also be wise. Maybe others can come up w/ something else.
How much money you got to keep it running? I have 2004 in Excursion near 150,000. Every time I say last time I spend more. Last bill was 3000+. Have 2001 Cumins near 200 on that. Zero problems tranny at 125. Original owner of both. In for state NY inspection now with check engine light on. What next? Change oil ford 5,000 dodge 10,000 with Blackstock reports. Fuel always leaks into fords oil. They say it's common. Could even try for 12 they said. I use regular oil not synthetic.
Change my oil every 7500. Great BLACKSTONE reports. Never have fuel dilution of the oil.
As I said - 200k miles - hardly anything spent after studs done at 100k miles. Also at 100k: BulletProofDiesel EGR valve, updated oil cooler, dummy plugs and standpipes (STC fitting and fuel pressure regulator spring done a lot earlier).
I think I need to join a Dodge forum to post that on .... jk.
When I was in California with my son-in-law we were admiring the Dodge diesel’s I looked at him with a smile and said in Minnesota they end up to be high mileage rust buckets ha ha 😆
For what it's worth:
I've had 4 6.0L; two were rock-solid reliable. 187K on a chipped '05 Excursion, & 376K on an '03 F350 dually. The other 2 were complete nightmares! Don't even get me started.
It's really just hit & miss with a 6.0L... :icon_rolleyes:
I've noticed that many folks who complain about the 6.0's also have them chipped and probably run them waaaaaay to hard.
Has anyone searched to see how much used 6.0L Excursions are selling for these days? I couldn't believe how much people are getting for them. Might be because it's still the only 8,000lb Diesel SUV available. I've got two 6.0's now and have had a few problems but my buddy has a Toyota Sequioa that has been a nightmare for him. I probably wouldn't own a 6.0 if I wasn't able to handle the repairs myself but that would probably be true for most vehicles.
Keeping dirt out of the HPOP system when it's opened up is a must otherwise you'll end up installing new IPR'S often.
I'm not sure we are complaining about the 6.0, more like someone asked advice and we are telling our experiences. It wasn't so bad to have one go belly up when Ford was paying for the reman engines, but it's pretty devastating to pay a lot of hard earned money for a truck, then when it's still under the mileage warranty miles, but 1 month out of the time warranty to have it die on the road, and have to spend 18 days in Dalhart Texas, and get a bill for $14,500.00 to get back on the road. Then Ford says, tough, too bad for you, lucky us.
BTW, I still drive a Ford Super Duty, but you are playing Russian Roulette with the 6.0. They are great trucks until they aren't.
I'm sorry that you had such a costly repair bill. I would be just as frustrated as you if that happened to me. I'm just saying that all motors have problems, some more than others. If you fly on United and they lose your luggage, you'll likely hate them. Maybe the United experience isn't bad for me and Delta loses my luggage.
From what I've read, seen on youtube and heard, the 6.0 can be hit and miss. I'm hoping you have nothing but problem free miles in your future. I've spent a lot of time working on them so I figure I'll just stay the course.
.....but 1 month out of the time warranty to have it die on the road, and have to spend 18 days in Dalhart Texas, and get a bill for $14,500.00 to get back on the road. Then Ford says, tough, too bad for you, lucky us.
It doesn't get any better as the technology advances. If you have a 6.7L with 50 miles on it and 99,950miles of warranty left and get some bad fuel then get moisture in to your fuel system, it will be similar money.... but you won't get a new engine. That just buys you a fuel system rebuild at the dealer and you will get the same answer from Ford as stated above regarding warranty coverage. Plus most likely, you still have plenty of truck payments to make on that shiny new rig after shelling out the $10K plus to fix it.
If you have a 6.4L and the engine fails, (apparently plenty of them do around the 200K mark), normally the engine is scrap and can't be rebuilt.
There is no inexpensive answer for diesel anymore. It just depends on which roulette wheel you want to spin!
Just to reiterate my point, my '04 left me stranded again this past weekend while camping in Clear Creek, CO. Drove there fine, sat for 3 days in camp, then would not start for the trip home. Scanguage PIDs showed no Cam/Crank Sync, No FICM Sync, so off to the local auto parts store to get another CMP Sensor, which usually does the trick. I replaced the CMP sensor with a Motorcraft sensor last Feb along with the Pigtail Harness repair, and it has run since then. Local auto store had 1 and I installed it. Still no start, no CMP/CKP Sync, no FICM Sync still... Jiggled wiring, checked other PID's (ICP, IPR, checked Oil level, etc.) then finally gave up and towed it out to the road with my other truck... Just for grins, I tried to fire it after taking a pounding on the washboarded rocky dirt trail, and it started right up... I'm guessing it's the harness at this point, so I'm in the process of getting a new one and will go through all that hassle with no "for sure" knowledge that is the issue...
Right. To "reiterate your point." But how is a harness problem directly related to it being a 6.0?
I seem to recall the 7.3 psd having a common chaff point. I also recall the idis having trouble at a engine harness connector.
But I guess those are all the 6.0's fault as well, huh?
Take care of your stuff with preventative maintenance (like common chaff points on wiring harnesses come to mind) and most issues will go away.
Oh now you wanna talk about clogged oil coolers? Hmm, do some maintenance and it won't clog.....
Sent from my SAMSUNG-SM-G930A using Tapatalk
Remember...an '04 is a 15 year old truck now. I get that the 6.0L has had more than it's share of issues, I get that the dealers were a long time figuring out what was really going on and left a lot of peoples trucks sitting on their lots with large monthly payments and no truck to drive. We all know Ford paid ridiculous amounts of warranty claims trying to save their sorry butts from this mistake.
But now here we are, it's 2018.
1. We now have seen just about every conceivable issue that this truck could have.
2. We know what it takes to fix them properly unlike the past when dealers would throw an EGR cooler in them and ignore the oil cooler because they didn't know any better.
3. The aftermarket has stepped up and in some cases provided some decent support for parts and we have the knowledge to know which ones are a safe bet and which ones to avoid.
4. We have free scan tools that run off our phones to monitor these trucks.
5. We can buy a brand new, not reman turbo from Garret for less than what dealers charge for a 4 wheel brake job.
6. These trucks are cheap to buy and the rest of the truck is pretty stout, I'd put the balance of the truck up against a GM or Dodge all day long.
You either see the value in where these trucks are at TODAY, not what they did to you over the years, or you don't.
You either decide to maintain them like a high maintenance girlfriend or you should move on. Life is too short to be angry at your truck on a daily basis.
These trucks are not for everyone and those of us who like them are very quick to state that when asked.
I run mine commercially from the mid west to the east coast. I am all about cost per mile and by learning the truck, carrying some parts and tools on the road, doing as much maintenance as possible when the truck is home and not having a truck payment in 6 years, I believe this truck is delivering... for me. If my neighbor came over who doesn't work on anything in his garage and asked me if one would make a good used truck for him to run around in, I'd tell him to run like heck from it.
^ Exactly.
If it leaves you stranded, it's from your own accord/laziness.
Even the oldest 6.7 is now going on 9 years old. The permanent fixes are out there.
Does anyone remember the Seinfeld episode where Jerry’s mechanic refuses to give him back his car because the mechanic felt Jerry neglected the maintenance?
It was Golden.
Thanks 79 Jasper, personal attacks on my character are most helpful... I guess I need a self help course to address my perceived laziness...
Wasn't necessarily the road I was heading down, but if the shoe fits....
Sure, some stuff isn't preventable, but when we're talking about common "problems," that's what I'm after.
I believe!!!-----If one addresses the known 6.0 weak points and the associated problems BEFORE THEY OCCUR, drives like he cares about his truck and NOT just how it "looks" and NOT with the pedal to the metal, DOES NOT chip to get as much power as possible and does all the routine maintenance like good, thorough coolant flushes and oil changes, I'd say that there is a good (actually DAMNED GOOD chance) that the truck will do its duty for many years and miles. Am I wrong? if you think so, tell me why. My 6.0 is a late build (late 2006 I think--truck is a 2007) and I've had some ancillary system problems, but only ONE that is directly related to it being a 6.0 Diesel. Yeah, I have my fingers crossed, but I am hoping it goes to maybe 400K or more before anything serious goes wrong.
21 - 40 of 41 Posts
