I replaced the fuel pump on my '97 Powerstroke. I found the plunger so disregard the post before this one. I didn't know how to cancel it.
I am still leaking...looks like more than before. I can't see from where it's leaking. But it is really coming out from under the truck. Looks like it' s coming out from where the tranny is bolted up. I couldn't see from any other place. I didn't see any leaks when I put my flashlight in there where the pump is. Just a whole lot of diesel fuel. Can the canister leak? a couple of years ago I had to have my canister replaced. That was a nightmare, I could actually see the fuel gauge dropping as I was going home as fast as I could. I had to stop and refuel...I was only about 10 miles from home. Where would I look to see if the canister is leaking...from the bottom?
What is that little metal thing in the bottom of the canister? I noticed when I was wiping up the crud from in there it had come dislodged from it's resting place. It almost looks like it was soldered down, but it was moving when I was wiping it out. Could that be the problem?
