Hello- I have done a bunch of work on my 05 6.0 which included removing oil cooler-valve covers- turdo-front cover-intake etc...now that its fixed I have a oil leak thats eventually soaking the front of my engine-I have removed the fan/shroud and cleaned everything with a pressure washer-brake clean and air hose- now I am running the truck with the fan/shroud removed while adding continuous cool water at the degas bottle and the drain valve on radiator open to keep the engine running cool- thats working...after 20 minutes or so the only leak i can find is showing itself of all places on the metal heater hose tube in the pic?
The tube is staying dry above it- the oil cooler area behind it looks 100% dry- valve covers are not leaking on it- any ideas where this oil is coming from?
http://roughneckcity.com/upimg/image/upimg_file/1478/original
