I have a 99 7.3 with a manual tranny in it, last week I was climbing a pass and the truck started running real rough and lost power. Once I got to where I was I tested the uvch as directed and sure enough the passenger side had a dead hole. Git the truck into the shop and they fixed it all up and was running great. Ran great for a day now it idles ok and has almost no boost, 4th gear uphill with the pedal to the floor gets almost 5 psi. Before it would go up into the 20s. It also seems like it's not fueling at low rpm. When I go to let the clutch out at a stoplight or something i have to almost dump the clutch to keep it from stalling. On a slight hill I have to start in low and it'll barely get going. Once I get over 1200 or so rpm it picks right up but just sounds rough. Egts seem normal. Truck has a chip but it's on the stock setting, it has a 4inch turbo back exhaust. Otherwise it's all stock. I have 1 code for the ebpv malfunction. From what I have read guys are saying if the valve is stuck closed you can only get up to 35-40 mph, but I was able to cruise at 70-75 on flat ground. Any sort of hill and the truck falls on its face. On a hill I can normally pull at 70mph in 6th I was barely able to pull at 30mph in 3rd. I checked the uvch again and all is good there. Looking for some direction please. Fuel filter is new, oil and filter are topped off and have about 1000 miles on them. Tha ks fir any help
