Hi; 2000 GMC 26ft bobtail with a CAT 3126 ,manual trans,air brakes,air cond.Parked at loading dock, 6 hrs later "no start".Engine chanks fine,spray starting fluid and it starts,did it 3 times and the last time i contiued to spray for 15 seconds.Its has a bad injector,leaks quite a bit of oil,got hot 1 time due to hose but didn't do any damage.I checked the primer and the pump was hard. In back of the pump on the inner timing cover both cam sensors have fresh oil on them and the connectors. I want to pull codes,does any one offer software for laptop along with harness adapter.Down loadable manual or manual on CD. Any thougths. Thanks Jeff
