BLACKCLOUD,
Here is some info on my CCV mod
Click on CCV link in my signature for pictures
garyT
I make up my CCV from ABS pipe. It is appox. 3 1/2" outer diameter and 6" long. It is filled with stainless and nylon mesh has a drain petcock and is mounted under the driver's floorboard
CCV MOD INSTRUCTIONS
1:Remove top of air cleaner, rubber intake hose and the solid piece that the OEM CCV goes into (if you can remove the rubber elbow then leave the piece on).
2:Remove the CCV breather on the top of the driver’s side rocker cover.
Be careful, there are “O” rings under it. Clean it up, put some grease on the “O” rings to hold them in place, turn it 180 degrees so the outlet points to the rear and replace it.
3:Mount the new CCV bracket under the driver’s side floor about 14’’ from the fender well directly in back of the tire. This puts it to the left of the frame near the body mount. There is a lot of room here, hold the whole unit up to get an idea of placement and mark some holes.
4:un a ¾’ heater hose from the breather outlet OVER THE BRAKE BOOSTER (this is important!!) down to the bottom fitting on the can. You may need to use an elbow where it comes out of the breather on top of the engine. It is important to run the hose up and over the booster as this lets the heavy oil vapors coming out of the breather to condense and run back into the engine.
5:Run another length of hose from the top outlet of the new CCV back to the original piece on the intake.
If you don’t want to do that you can fabricate an inlet into the air cleaner box somewhere. Home Depot has lots of plastic fittings you can fool around with, some electrical conduit fittings will work also.
