I am about to hit 30k miles. The maintenance schedule states it's time to change the automatic transmission fluid and external filter element. Is this something I should try for the first time? My only experience is 20 years of oil changes and light maintenance.
From reading the "Owner's Guide" it sounds easy, just like changing the oil. Is it?
Here is how I would do it:
> Drain trany fluid
> Remove and replace external filter element. (P/N# FT-145)
> Refill trany fluid,17.5 quarts, Mercon SP ATF
> Check levels on dip stick
Is that about right? Is there a more detailed written procedure somewhere that I can download?
Thanks for you help!
> Drain trany fluid
