1 - 9 of 9 Posts
With all this horsepower talk why has no one changed the camshaft in a 6.0. Does no one make one, you would think you could get a cam made for less than some of the boxes. Just a thought /ubbthreads/images/graemlins/shrug.gif
Camshafts are not as important when you are using a turbocharger. With the 6.0's 4 valve head getting air in and exhaust out are not a problem. I suspect changing a camshaft in one of these engines would cost more in labour than a chip and would definatly void warrantys.
A cam swap would only be viable if you pulled the engine and were searching for every little bit of hp. There are many other areas that have yet to be used that are easier than a cam. The cam comes out the rear of the engine.
Tadd
Did'nt realize that the cam needed to come out the back of motor talk about major pain. /ubbthreads/images/graemlins/shocked.gif
just cut the firewall /ubbthreads/images/graemlins/smile.gif
so do i need to make my hole behind the radio or cigarette lighter??? /ubbthreads/images/graemlins/biggrin.gif
Iwould say just under the radio and to the left a little. /ubbthreads/images/graemlins/grin.gif
hahah im not resposible for your damages if yall choose to go this way /ubbthreads/images/graemlins/smile.gif
1 - 9 of 9 Posts
