Had a short bed crew cab 2012 F350 with the 4" blocks in the rear. Just picked up a new 2016 F250 (also short bed crew cab) and leveled the front (1.75"). It exaggerated the lower stance of the rear end, so I want to get the bed height the same as I had on the F350. Obviously I need the 4" blocks and new, longer U bolts. Anything else? I have seen mixed statements regarding shocks, etc. Any driveline parts, etc? Thanks in advance.
From Ford...
I believe it also applies to your year.
· Banned
Do you have the camper package on your 250? It's recommended but not required to change the rear sway bar links as they are longer with the taller blocks. If you don't change them you'll be fine but your sway bar will no longer be level with the axle.
