I would not recommend running decarbonizer straight through the IP. I had two IPs ruined for me due to fillups of gasoline (Oregon has no self-service fuelling; the 1st rig the gas station's insurance Co. paid $3k to have all new injection parts (IP, injectors, lift pump); the 2nd rig the insurance Co. bought from me outright to avoid the same costly repair, toasted the IP in three miles). Gasoline has practically no lubricity at 2k PSI, and I imagine that Seafoam doesn't either.
Ditto what Pete said: fill the filter only into the outside holes when you fill the filter, otherwise the fuel you pour in goes to the IP unfiltered.
Well I still don't recommended it either. I put another 200+ miles on it again today and it runs better than it ever has. Remember also that the fuel will mix, probably minimaly, with the Seafoam, and some will return to the tank. Pretty hap hazard huh, well at 160k if eats a pump or injectors it's a good excuse to upgrade. I will let you know
when and if the injector pump comes out the tail pipe. -matt /ubbthreads/images/graemlins/shocked.gif
