My 7.3 has 350,000 miles. Doing some deep maintenance, I pulled the injectors and one of the injector cups stuck and came out with the injector. Coolant flooded the cylinder and engine internals. Not good. My plan is to remove the engine and see what repairs are needed. My plan is to keep this truck for the long haul. People can't believe it has this many miles and I want to keep it on the road.
While the engine is out, what other maintenance do y'all suggest?
I already have new IPR, ICP and CPS. Plus new HPOP lines to the heads and replacing fuel lines to go to a regulated return. I already bought a new upgraded GPR, EBPV delete pedestal and Wicked Wheel.
By the way, the stock turbo looks great... no erosion due to dirty air. Already have up-pipes and turbo back 4" exhaust.
What upgrades are suggested for the HPOP regarding seals and fittings?
What other than:
Check engine ground cables
Check all electrical connections and cables
Paint engine
Replace rear main seal
Differential oil & breather hose
What other than:
Paint engine
