99 f-250 4wd.it was having a problem with it cutting off and not cranking back up and then just not cranking up sometimes.changed the cps and it still done it.i told him to remove the chip and try it.well he forgot to unplug the batteries and remebered about half pull on the chip.he then shoved it back in and then the truck went haywire.4wd would not work,engine light on,wouln't rev past 2000(free rev) and blowing out smoke.he called me so i went out an properly removed the chip.it runs fine now so do you hink the chip is toast or would you try to reinstall it and test it?thanks
