As most car enthusiasts wash their cars on a weekly basis, often the door seals and jambs are forgotten as part of the washing routine. While driving around, the seals protect dirt, road grime, leaves and other nasties from entering the interior, so it is a common area for dirt build up.
The mix of particles in the dirt and rocks can scratch the surface of your clear coat allowing the bare metal to start oxidizing, thus creating rust. So it’s ideal to wash your car’s seals regularly and thoroughly with Autoglym Engine & Machine Cleaner – though this product is predominately used for cleaning engines, it’s also great at attacking dirt and grime, and is 100 per cent safe to use on seals and paintwork.
To begin, open your doors and inspect the area around the jamb and rubber seal. Then remove any leaves that are trapped by hand, or soft, stiff brush.
Then, simply spray Autoglym Engine & Machine Cleaner around the door edges using the small brush to agitate the cleaner into all areas, give extra care to small hidden areas and gaps making sure it is thoroughly cleaned.
To remove the cleaning solution, simply use a concentrated jet hose and hose away the solution away from the car.
Finish off by wiping and drying the door jambs and seal with a damp microfibre cloth to remove any remaining dirt.
For a complete care, spray Autoglym Vinyl & Rubber Care onto a Perfect Polishing Cloth and apply to the rubber trim around your car to give the rubber seals a glossy shine while creating a protective coating.
Follow us
Autoglym Canada
Autoglym Canada Blog
Official Autoglym Canada Facebook
Official Autoglym YouTube
We are here to help you
If you require car care advice, or are unsure on the right Autoglym product to use, please leave a comment or visit www.autoglym-canada.com for more information.
