I have a motorhome with a 2006 6.8L three valve V-10 and the five speed TorqShift transmission. It recently started making a very strange sound...
http://youtu.be/FKVNiwRtXyY
It happens when it's cold and I just start off driving for the first time. It also happens on upshifts under a heavy load (like when going up a steep hill). I've also noticed it happening when the engine is under a heavy load going up hill and I let off the throttle dramatically.
Everything seems to be running fine other than the sound and there are no codes.
Anyone have an idea what this could be?
Thanks!
Flex plate loose?
I believe I've isolated the noise to this box. It's mounted to the front of the intake manifold and has a four wire connector going to it.
Any ideas what it is?
Thanks!
