1 - 8 of 8 Posts
is there a trick to setting the clock on my 2000 f350? it has all stock stuff, lariat pkg with cd player...i had to disconnect batteries to change the PCM , now i cant figure out this clock...i can change pcm, o rings in hpop, pinion seal, but cant figure out the clock..im an idiot
Is there a menu button? With the radio OFF, push that, it should go to set hour, then set minutes, use the button you use for moving balance/fade to set I think. (all from memory on my 03, but should be the same I hope.)
No we don't have a manu button. Hold down on the clock button with one finger, then over on the left side there are two sets of left and right arrows on top of each other, one is the select for the CD, one set moves the hour up or down and the lower set moves the minuts up or down. IIRC, I hope this helps. You may want to right it down for next time and place in glove box.
No sh**t, sometimes this simplest things are a PITA
According to an article I just read after using Bing.com to find it, it said to have the radio ON, then push CLOCK, then use the preset buttons to enter the time. That's what I'm going to do tomorrow. Too late tonight. G'luck.
Hopefully he already figured it out. It would suck to go 8.5 years with the clock set wrong...
The artistcle I read was incorrect. At least, it didn't work for me. Sorry for the bum info.
1 - 8 of 8 Posts
