Sorry I didn't get back to this sooner.... I did a lot of checking around today. Here is what I found out: Talked to Ford parts and service at a couple of local dealers. Replacement parts depend on whether your truck is equipped with a dual mass or single mass flywheel (clutch disk and pressure plate). Pilot bearing and throwout bearing are the same for either. That is the only difference in parts, regardless if you have an F250 or an F550. I was told by one aftermarket manufacturer that dual mass flywheels were only used for the first six months of production on this engine, another told me they are all dual mass... Ford says that either are used, regardless of year. Have your service person check your VIN if you are curious to know what's in your truck before you have to tear it apart (mine is single mass). As for aftermarket or upgraded clutch, one aftermarket manufacturer said that Ford offers an upgraded pressure plate with more clamping pressure.... Ford didn't know anything about that. However, the part number for my replacement disk is an '05 part... the parts guy said the disk was changed, but didn't know what the difference was. Luk clutches is supposedly the original equipment manufacturer, but Dial-a-Clutch doesn't have part numbers to sell them. I did speak with Woody at South Bend Clutch. He told me that they are working on two upgraded disks, one will handle an additional 400 ft/lb torque, the other an additional 600 ft/lb, but they are NOT currently selling either one. Seems they are waiting on the blanks to be manufactured by another company... South Bend does all the assembly in house (friction material). I could not find any other company that makes performance clutches for these trucks yet, which really surprises me being we are coming into the fourth model year for this engine/tranny combo. This is just what I have found out so far.... I definately appreciate the input on here. If anyone else has any other info.. please post. Also, I have a thread about this on the other forum.. wasn't sure which to post this on so I sorta did both... sorry if you read the same stuff twice.
