Assuming you haven't managed to get it done already, it's really not a big deal. You may need an extra pair of hands and/or eyes to make sure everything lines up right, and it can be hard to push everything in as tight as it needs to be.
Basically, down under the truck you'll have a metal rod (mine was nice and shiney, easy to spot) running roughly perpendicular to the clutch pedal, and it goes inside the clutch master cylinder, which is pushed through the firewall. You'll have to disconnect that rod from the clutch. A big screwdriver helps for this, but you have to be careful not to break the rod of the little plastic insert it has. If you do break it, you'll be going back to the parts house, but it's a relatively inexpensive part.
Next, you'll have to disconnect the master and slave cylinders. You just turn them about 45 degrees and they should then pull out easily enough. Once you get them out, it'll be obvious how they are held in. Remove the two little plastic dowels that hold the resuvoir... resevoir... thingamabob on and remove.
Assembly is the reverse of dissassembly with one little exception. Install the slave cylinder first (it's the lowest part on the assembly). The slave cylinder has a couple of plastic tabs that hold its push rod in place for easy assembly. If you install the master cylinder first and apply any pressure, it'll break those little plastic tabs and make installation of the slave cylinder just a little bit harder (found that out the hard way).
HTH, and sorry I didn't get this to ya sooner.
