Within the last 6 months or so, I've just started noticing that the clutch master cylinder moves back & forth where it's mounted through the firewall whenever the clutch pedal is depressed and released. The movement is quite small - maybe 1/16".
Questions -
1. Is this normal? I don't recall the 'clunk' when it was new.
2. Has a part worn and fallen out that would have taken up the 'slop'?
I'm taking the truck in for regular service in a couple of weeks and will have them look at it then, but I though that I'd check here first to see if this is normal or not.
John
