Comming home yesterday evening the clutch pedal just stayed on the floor after I went into second gear when leaving the last stop sign before my home. It was clear I had lost my clutch and I just drove on home shutting it off and standing on the brakes as I got home.
So now I can lift the pedal if I want and I can push it back down, where it will stay. I can hear a clear squishing sound at the clutch master cylinder, but I can't see any fluid. I have not pulled out the slave cylinder end of it.
There are two possibilities, one is a broken throwout bearing aculating arm and the other is the hydraulics - which I understand is sold as a unit, slave, master, hoses, and the small reserviour.
That all sound about right to you guys? Got any suggestions on how I can tell which it is? Any idea on parts cost?
Thom
Thom
