Everytime I am on the throttle for a long time, i keep getting the p2290 code.I believe it is for low injector control pressure. Only get it on a long full throttle run. does this mean I am starving it for fuel or? Just getting tired of seeing it. Truck seems to run perfect.
This code means that you have low Oil pressure output from your high pressure pump. This code could be real, or it could be created by a box, depending on which one you have. I need more info to help out.
Tadd
