my truck gave a code p0122 this morning. it said it was a throttle positioner low voltage. i cleared the code before leaving work to see if it will pop up again. that was about a 27 mile drive and it never came back. what is getting ready to go out and what do i need to do to fix it?
Sounds like your go pedal is going out.
Do you have adjustable pedals? I think there was a TSB about the pedals going bad on those trucks.
These trucks are "fly by wire" and need to see certain voltages across different parts in order to run right. If your getting low voltage across the pedal, the truck may not run correctly, or may go into a permanent idle, and not rev up.
mine does have adjustable pedals. how expensive will it be to get a new go pedal?
does anybody know where i can get the adj. go pedal at a reasonable price or can i put a nonadj. pedal in its place?
