Well i finally found a tool that could retrieve my DTCs. From what ive researched, the first 2 are benign codes, like a burnt bulb at some point, or something of the sort. However, with the boost/boost gauge/lack of power issues Ive been having, I think there is something to the P1247 code, which is for low boost pressure. Let me start with the gauge. My Autometer boost gauge has sat at -5 since the day i bought the truck. With engine off and at idle, it sits at -5. While cruising, it barely moves at all, maybe 1 psi. Even when i step on it, it does not move more than 1-2 psi. Also, if you were a party to my other thread about having no power when downshifting, this all seems to tie together. The consensus ended up being that the trans was doing what it should, but upon stomping on the pedal and downshifting, the truck goes nowhere. Let me reiterate that this is all without towing, no load at all. Anyway, it seems that the code, gauge reading, and lack of power are all linked. I checked all the turbo boots, and tightened the ones that werent completely tight, with no change. I checked the fitting on the back of the gauge and its tight and the plastic tube looks good. I checked the hose going from the MAP sensor to the turbo y pipe and it looks good, no cuts or holes and feels tight as well. I took a picture of one of the boots and either the up-pipe or down-pipe, not sure which one it is, but it has the blue boot and i did notice the blue boot has what look like a good amount of soot on it, even though the boot clamps are completey tight. Also, the pipe has been wrapped in foil by the previous owner for some reason. Anyway, guys if you could give me your thoughts, i would really appreciate it. The picture is at the top of the thread. Thanks guys
