I have a 2000 f350 and my code reader is giving me these codes p0500,p0471,p0470,andp0732. I am not sure what they are but I have noticed the truck has been a little harder to start in the cold lately cold that have anything to do with that? I also have the hyperteck programer could that have anything to do with these codes? Any help would be great, thanks
P0470 — EBP Exhaust back pressure sensor circuit malfunction
Probable causes: Biased sensor, open signal return
P0471 b EBP Exhaust back pressure sensor circuit performance
Probable causes: Plugged, stuck or leaking hose
P0500 b VSS Vehicle speed sensor malfunction
Probable causes: Sensor, circuit, PCM, PSOM, TR failure, low trans. fluid
P0732 — GRV Gear 2 incorrect ratio
Probable causes: Mechanical/hydraulic failure, 4x4 switch failure
