1 - 12 of 12 Posts
I have a 2004 f 250 6.0 super duty that is having trouble with the cold start it turns over but acts like its not getting a good prime but it smokes like a ***** but once it started and runs for a little it starts right back up .
Sounds like something with the glow plugs...relay?
What color is the smoke?
Do you still have the EGR system?
Check FICM voltage
With the codes you are getting, I doubt that you are getting FICM sync.
How did you check the FICM voltage? KOEO and then also when cranking? What were the voltage values in your tests?
Even w/ good voltage the FICM can be a problem. Do you have access to a known good FICM you can swap with?
Mark, i have same problem, as when i PM'd you. FICM changed by ford 11 months ago. whats procedure for checking ficm? sorry guys, disregard, found the procedure in a search.
it is possible you don't have the most recent flash. My 04 had the same problems, had it reflashed and it was like a new truck, problems went away
when it cranks over it goes down to 35.8 but then goes right back up and I do ill have to try that and let you know.
You have a bad FICM with that voltage.
I started mine once without waiting for the glow plug lamp to go out. Took a couple days running before it quit smoking at start up.
1 - 12 of 12 Posts
