Hey guys, I have found a few similar threads, but not one that really answers my question. I hope someone can please help!
What are some of the warm up times for a 2012 6.7 diesel? Mine just doesn't seem to cut it. Here is what I get:
Start it up. Engine oil temp (according to build in gauge app) is 23 degrees, and let truck idle.
In 20 minutes, it is up to 100 degrees.
In 30 minutes, 110 degrees.
At 1 hour, 130 degrees.
Start it up. Engine oil temp is 32 degrees. Let idle.
In 11 minutes, 85 degrees.
In 30 minutes, 118 degrees.
In 45 minutes, 127 degrees.
In 1 hour, 131 degrees.
It levels out at 130 degrees and never gets any warmer (at idle).
I also notice that it cools off whenever I stop driving, and let it idle:
After letting truck warm up to 85 degrees, drove it for 15-20 minutes. Engine oil got up to 150 degrees. Parked it and let it idle for 15 minutes. Engine oil temp dropped back down to 140 degrees.
Cab never did really warm up, and it was 35-40 degrees outside.
Another time, it dropped from 195 degrees to 163 degrees in 23 minutes (it was bout 25 degrees outside).
This is the first 6.7 I have owned. Does this seem right to you guys? The dummy gauge doesn't even move until the oil temp gets over 170. So most of the time, it just sits on the cold mark. I get that diesels can take a long time to warm up....but not to warm up at all? But lets just say they are "cold blooded", or whatever the asinine terminology people want to throw around is, shouldn't it still at least maintain operating temp (once hot)? What would cool it off so fast? And what kind of retarded engineer would design a motor that can't even maintain it's own operating temp?
Also, please understand, right now, I am just interested in figuring out the engine temp. The cab heat is a different story. I have the same issue as I have seen with others, where, even after I drive it up a hill for 29384092387560834908230956230985 miles, and get the operating temp up to 190, the heater will only blow hot air if rpms are over 1,100. Anything under, and it is just luke warm air (I see a difference of about 30-40 degrees with temp gun).
This history I know on the truck. After buying it, realized the heater wasn't up to snuff. Checked coolant and saw it was low. Found a leaking main radiator. Had radiator replaced. Got truck back, still sub par heat. Also noticed engine temp dropping at idle etc. Had the Main thermostat replace. Still have sub par heat. I think it is slightly better then it was before replacing radiator...but still.
Anyways, sorry for the long post, I really appreciate any help. I have no idea what else to do, or check, if I can't leave the wife and kids in the truck while I go shopping, might as well sell the damn thing. Which is lame, because I love everything else about the truck. I don't want to drive another sluggish gas engine again after driving this power house.
