Vendor
This ad is for a READY TO DROP IN AND USE, COMPLETE and RUNNING 2004 6.0L Powerstroke Diesel ENGINE (Late 04 Build). This engine is still in a truck, which can be driven. The truck has not been in a wreck, it is not being sold because of any type of damage. The truck is being used for a project and the engine and trans (being sold separately) are not needed. This engine has 141k miles, RUNS GREAT and has a lot of upgrades:
- All (8) injectors replaced 60k miles ago (approx)
- Cylinder Heads Decked and O-Ringed
- Engine Block Decked
- New Head Gaskets
- ARP Head Studs
- EGR Delete
- Coolant Return Kit
- Oil Cooler Replaced when Headwork Performed
- Regulated Return Fuel System
- Brand New High Pressure Oil Pump
- Brand New HPO Stand Pipes
- Brand New HPO Dummy Plugs
- Brand New Water Pump
- Stock Turbocharger (only 30k miles since replacement)
- All Above Work and Service/Maintenance Performed by myself or Strictly Diesel
This truck has only run mild TOW and ECONO/STREET tuning since the head and block work were performed. It has not been abused.
Engine is being sold as-is, no warranty. It is a complete engine, turbo to oil pan, cooling fan to flywheel, "intake elbow" to "turbine housing" (not including the cold air intake, intercooler and tubes or exhaust downpipe). It also does NOT include the FICM or the engine PCM, but the entire engine wiring harness will be left in place.
Asking $5000 o.b.o. for the complete engine (no core necessary)
I will NOT part this engine out, please don't ask about buying the turbo or injectors or any other individual engine components. This engine runs too good to be disassembled and parted out.
Engine is located in the North Phoenix (Arizona) area and can be seen/heard/driven by appointment. PM or E-Mail ([email protected]) to set up a time.
LOCAL SALE or CUSTOMER PICKUP ONLY! We're not setup to pallet and ship engines...sorry.
This is a private sale. Payment will need to be cash or cashiers check. Cashiers Checks will be verified with the bank.
Still for Sale?
Vendor
Unless something falls through, no. I have a buyer and since it's someone I know I'm 99.9% certain it's gone. It's not out of the truck yet so anything can happen...but hoping to have it out this weekend.
Hey Dennis,
Are you swapping in a Cummins? If not, do you mind me asking what is going in place of the 6.0?
any other 6.0s
Got any other 6.0's available? Or at least the bottom ends? I just lost mine last weekend - cyl#2 no compression and not sure if rebuild and replace with a running/rebuilt motor...
Trying to find local options (Here in Gilbert).
Thanks,
Lloyd
Vendor
Discussion Starter #7
I don't think we have anything in the way of "used and running" but we can certainly help with the repair. I'm out of the office for a while, call Gary at 623-582-4404, he can let you know what options we can offer you.
{Sent from my stupid iPad...not responsible for typos}
