What is a good method for compression checking the cylinders? I plan to swap out injectors this coming week and I plan to check compression per cylinder why I'm in there. I'll be using the glowplug adapter and checking compression before I disturb the injectors. I may recheck after the new injectors are installed and the cylinders are purged for any excess fluids, just for piece of mind.
I plan to pull all the glow plugs prior to compression testing for ease of engine spooling.
Should I pull the main fuse to the PCM? Should I just disconnect the injectors at the valve cover gasket connectors? Anyone that's done this, please let me know your opinion and/or opinion.
Thanks, Trav
Thanks, Trav
