Single use - per tire...
70 psi - 2895 lbs.
75 psi - 3040 lbs.
80 psi - 3195 lbs.
85 psi - 3315 lbs.
90 psi - 3450 lbs.
95 psi - 3640 lbs.
100 psi - 3715 lbs.
105 psi - 3845 lbs.
110 psi - 3970 lbs.
Dual use - per tire...
70 psi - 2720 lbs.
75 psi - 2860 lbs.
80 psi - 3000 lbs.
85 psi - 3115 lbs.
90 psi - 3245 lbs.
95 psi - 3415 lbs.
100 psi - 3490 lbs.
105 psi - 3615 lbs.
110 psi - 3750 lbs.
70 psi - 2895 lbs.
75 psi - 3040 lbs.
80 psi - 3195 lbs.
85 psi - 3315 lbs.
90 psi - 3450 lbs.
95 psi - 3640 lbs.
100 psi - 3715 lbs.
105 psi - 3845 lbs.
110 psi - 3970 lbs.
70 psi - 2720 lbs.
75 psi - 2860 lbs.
80 psi - 3000 lbs.
85 psi - 3115 lbs.
90 psi - 3245 lbs.
95 psi - 3415 lbs.
100 psi - 3490 lbs.
105 psi - 3615 lbs.
110 psi - 3750 lbs.
