Got a parts list together if anyone wants to dive in. The Ford stuff is:
F81Z*7277*BC. Boot/trim
F81Z*7210*AB. Shifter upper
4C3Z*7210*BA. Shifter lower
4L3Z*7213*AB. Knob
4C3Z*7B051*JA. Linkage rod
6C3Z*7B106*A. Linkage arm
Around $325 for all. I used a piece of 6061-T6 aluminum plate, 1/4" thick, I had from another project, & the motor for a template for the holes. The rest of the bits came from Ace hardware:
(2) 1-1/4×3/4×1/16" bronze thrust bearing
(1) 1-1/4×3/4×18 gauge zinc machine
bushing
(2) 5/8×5/16×1/4" steel bushing/spacer
(2) M8x1.25x25mm mini-head flange bolt
(1) M8x1.25x25mm flat-head socket cap screw
(2-3 ea) M6 & M8 spring washers
(1) M6x1.00x20mm socket-head cap screw
The flat-head socket cap screw goes in the upper-most hole so the linkage clears. You must also cut a notch in the linkage arm to clear this bolt in low-range. For this reason no spacer is used here, instead I drilled a hole right below & tapped for the M6 cap screw to mount from the back of the plate & act as a foot. Use the spring washers to get the bolt head & spacers the same thickness. The pin on the linkage arm is welded on from the back & I had to remove most it for clearance to the case so I ground 2 deep cuts in an "X" across the back of the pin area & welded, then ground smooth. Take your time opening up the hole on the arm to fit the shift-shaft, as play will cause wear. That needs to be a snug fit. Bronze bearing goes on shaft first, then steel, linkage arm, & you should have just enough shaft left for the other bronze. Barely. Grease them all liberally as you install. The plate holds it all on. It's a slight interference-fit.
4L3Z*7213*AB. Knob
bushing
