Hello Everyone.. I wanted to update I saw a thread not sure if it was on here or the other forums.. But I purchased a Sinister Coolant filter.. I also had a 100 PSI gauge.. (I know 100 PSI is overkill) but I wanted to share with you guys it works great! My pressure never exceeds 10 PSI from what I have been seeing. It's under the hood so if I want to check I do have to open the hood. But I'm happy it worked. I'll try to post some pictures.
And you can install a pressure sensor so you can tie in coolant, fuel and oil pressure to a 100psi stepper gauge, switched through a rotary switch.
