Lower hose on the water pump is leaking. It looks like its the hose like the band clamp is the problem. I am not sure though i replaced the top neck last year, does the lower one rust out too?
Thank you for any info
JPC
My experience is the junction between the water pump and the lower neck is the most frequent culprit. The pump side seems to corrode and leave a poor sealing surface for the O-ring. The "cure" is a new pump.
Thank you RT,
All the FORD parts and pump should be here Friday. How much coolant should I expect to loose. I am not flushing it at this point. Time is an issue and we have to take our brand new Explorer in cause the A/C has a major issue and smells like burnt wires. So I will be down a car this week. Is the Zerex G-05 ok to fill it back up with?
Thank you
JPC
That's Ford Gold equivalent. I wouldn't use it. An extended life coolant is preferable, but you really need to use what you've got in there until you can flush. If you drain the radiator into a clean container, you can reuse it. Expect about 3 1/2 gallons. The Airtex pump is OEM and about $40 at Rockauto.
Thank you RT.
I have never drained this truck of coolant. Had it flushed 18 months ago.
Do I drain the radiator out the bottom valve and fill into the degas resivoior. Seems like a chance for air to get in. I tryed searching on the Web no luck about filling and bleeding at least on my year.
Thank you JPC.
That's exactly what you do. These models are self purging. Very rarely someone gets a bubble stuck in the heater core but it will work itself out before winter.
