I have an 08 350 with the 6.4. I have some coolant leaking on driver and passenger side. Not sure what it is exactly or where it's coming from, was hoping for some help. If you look above the tire in the wheel well on driver side, there are 2 small hoses that spear to be metal. The leak on this side looks to be coming from whatever the connect to. Haven't found source on passenger side, I will look again today and get a photo of possible. Attached is photo of drivers side leak zone.
Look around your rad, those radiator are prone to failure. The rad is basically mounted on the body, so when it flex, rad crack
I think it's metal hoses that are leaking. On passenger side I can hear it pumping or sucking every 30 seconds are so. It's back behind the intake, a silver metal tube.
