Hey there,
I'm not sure if my mind is playing tricks on me or not...
I'm wondering if my truck is consuming a little coolant. I can't see any physical signs of leakage and I did an engine oil sample which tested negative for glycol. Yet I am quite sure that the level has dropped in the past while.
I did top off the reservior level a few weeks back, unfortunately it was at the dealership and the engine was warm. Now when it is cold and parked it seems that the level is lower than when the engine runs. Right now (parked and cold engine) the level is below the MIN line. Is mild coolant consumption "normal" for these engines? Is there a real good way to test if I am loosing coolant?
Thanks in advance!!
Thanks in advance!!
