I have a 2011 with the 6.7 and I was wondering if the service (off hand I believe due at 105k ) is just a drain and fill for both the primary and secondary system or is it a system flush?
I called the dealership and I was quoted around $500 for a flush of both systems. So I called my local "SpeeDee" auto service center and I was told the radiator could not be flushed because of the connectors on the primary system and it could only be drained and filled but to do both systems would cost $220. I was told they have the latest flushing systems and even Ford dealer would not be able to perform a flush of the primary system.
So I would like to know who is right? I have done my best to research this and I can't find the answer.
My invoice from Ford says:
"Cooling system diagnosis and Flush includes two gallons of coolant and Ford Flush."
Installed VC1 : Cleaner - Oxidation Neutralizer [email protected]$7.62
Installed VC3 B: Anti-Freeze [email protected]$22.35
Flushed Both Cooling systems
grand Total with tax $223.48
Thanks for the post I may try calling a different dealer.
