I had another thread that went to this problem. I recently pulled my used motor that I installed in my motorhome. It had 185000 miles on it. It's an 89 7.3 idi with an aftermarket ATS turbo on it. From what I can assume, it was put on the original truck fairly early on. It was a F350 flat deck, special order built for the customer. The clutch had been changed to a Luk solid flywheel and the tag was still on the tranny. The waste gate rod has never been tampered with (ie no excesive boost levels).
When I installed it I put a boost and egt gauge in to monitor the vitals.
Boost - 7psi
EGT - max 1150 climbing mountain passes.
Compression is between 400 and 450 on all cylinders cold
Now to the real problem. I shoehorned the motor out to fix some oil leaks (external from the head gaskest) and some water leakage/useage. Once I got the heads off, I see that all 8 pistons are cracked about an inch long and all in the same place.
What I'm wondering is,
-how common of a problem is this
-how much longer would it run the way it was
-Any comment or suggestions
I'm looking at a $6000 bill to do a long block in a recreation vehicle.
Here's a couple of pics of the pistons.
Thanks for any or all input.
Boost - 7psi
