1 - 10 of 10 Posts
96 f250 7.3 started abs was running fine I walked into my house come out the truck died and now cranks but no start thinking cam sensor or glow plug relay any thoughts?
The first thing that I would think is no fuel.
Are you getting any tach movement when cranking the engine over?
Have you checked the oil level?
Have you opened up the fuel filter bowl to see if you have any fuel? Did it die just idling, or when you tried to drive off? They will idle all day with not much fuel, but die if try to drive them.
Where are you located and what kind of temperatures? You mentioned replacing GPR. What about your glow plugs? How old are they and are they Motorcraft? jelled fuel? Just trying to go through some possibilities.
Have you checked the fuel pressure yet on the side of the filter housing while cranking the engine over?
Agree with Bugman, Change the fuel filter too. I seriously believe that my clogged filter starved my fuel system,
and it took me days and a new starter to get it bled and restarted.
check the screen filter on the bowl..
1 - 10 of 10 Posts
