Anybody have this problem, i replaced shocks and thats not it but i noticed the left side leaf springs actually rest on top of each other and there is a rust mark like they are rubbing. The right side leafs have a slight gap. This only makes a noise when i turn right and also when i turn right and hit the brakes making the truck dive in the front.. Truck has 103,000 on it now.. thanks!
There's also some white shim/insulator bushings on the leafs...mine will squeak from there...start with the simple things first...
Work from the cheap to the expensive. Have you had the ball joints done? I'd give the bushings and shims a close look first. Good Luck.
i had a place near myself look at the front end, ball joints etc..Its a well know 4x4 truck place!!
