21 - 31 of 31 Posts
Discussion Starter #21
I have to finish loading these trailers, but I will give him a call little later today. I appreciate that very much for taking your time to find out if it is over 75". As many people that want to sleep in these CCS, you think they would advertise the 75" DOT APPROVED. I'm located in AL.
I log off duty. If a cop asks me what I was doing during my off duty time I just tell him that I wasn't in, around or on my truck. I don't have to prove myself innocent, he has to prove me guilty. If he doesn't have any evidence that I slept in my truck (and I am not going to him any by admitting that I did) he cannot prove his case.
The cop can ask for a motel reciept if you can't prove where you slept, you WILL be put out of service. Seen it happen more than once.
They can ask all they want, but you do not have to provide a receipt. If you had family or friends that you spent the night with there would be no receipt.
All they need to know is that you were off duty for the specified hours. There is nothing wrong with spending 10 hrs at a truck stop lounge, or sleeping on a rest area picnic table. If they want to give you a hard time start making your way up the food chain until you get to a supervisor that actually know the laws.
I am having a Freightliner Truck dealer build a pickup/hauler from a NEW M2 106 crew cab with a sleeper bed for far less than the cost of a Sportchassis. Sportchassis is an aftermarket manufacturer that sell packages - beautiful but not inexpensive. My truck will have a 5 year warranty, full leather, nav, dvd, air brakes & suspension, upgraded heated/cooled seats, automatic chains for snow driving...etc. for less than $80,000.00 BRAND NEW!
That is in correct. Sportchassis is a division of Freighliner that makes the package.If they weren't Freightliner Corporate wouldn't have it under their recreational use tab. [URL="http://www.freightlinertrucks.com/trucks/find-by-use/recreational/default.aspx[/URL] Now with that said buying fully loaded pickups(driver comfort is key to good production for a company) and having to trade them every 2-3 years because they are tired is far more expensive then buying one Sportchassis, and keeping 2-3 times as long or more. My friend finally realized this, and started switching over not too long ago. His trucks usually go 2-3k miles a week. Running virtually 24 hrs a day. No sleepers needed for these trucks. He does have two brand new Volvo tractors that are used for longer distance hauls. He hauls for his brother's auto tuning business, double duty horse farm work.
A trick i learned a while back is put every one of your receipts in a stamped envelope addressed to your company's mailing address. In order for the DOT to open the envelope they would need a federal search warrant.
If the ask to see your receipts for tolls or motels tell them you didn't get one. IF they cant PROVE WERE NO somewhere when you said they were they got nothing on you. The burden of proof is on them.
The burden of proof is almost always on the one WITHOUT the badge, apparently some of you haven't been thru any DOT checks in certain states.
Attitude will get you nowhere, they can put you out of service and find anything they want, YOU will be the one to challenge whatever they write you for. Going up the chain of command usually results in NOTHING, especially in the scale.
I've seen it many many times, drivers who know it all, the DOT love to put them in their place.
They can keep you there as long as they want. They enforce the federal regs, BUT the state regs supercede the federal regs, so basically they can make it up as they go.
The guy with the badge holds ALL the cards ALL the time.
Any of you guys ever been thru a DOT check ?, I think not.
they key is to know the laws like the back of your hand:read:, and make sure you are following every single one of them. there shouldnt be any "the trick is" or "they need to prove if" because they can and will find something. i got to the point with one check point, after passing through it on almost a daily basis for years, one DOT official, would basically give the truck and my logs a quick lookover, kick the tires and i was on my way, because he knew i was legit on everything. oneday at the same stop got a guy who must've had someone piss in his cereal that morning, because he checked EVERYTHING and wound up putting me OOS because my brakes were not adjusted "properly" apparently his adjusted properly and mine were totally different. he along with other people i have seen adjusted them; all the way tight, backed off 1/2 turn. my way and everyone in my family and our mechanics all adjusted them; all the way tight, backed off 1/4 turn, making the brakes that just that little bit tighter. but because they weren't up to HIS STANDARDS he put me out of service until i got a wrench and adjusted them, and he would not let me use his wrench to adjust them! so moral of the story....... yes they will get you if they want to get you, there is no way around it... the law is the law, and if you think you are smarter than them, they will make a law to prove they are the smarter ones!
went through my second level 1 in two weeks today (different trucks)
i would like to know if DOT would allow for removal of the passengers seat in an f 350 crew cab to create a sleeper birth for a single driver owner operator hotshot rig... thanks
i do not see how it would violate any of the requirements of § 393.76 other than the restraint system which would not be a factor as the truck would not move while the driver is in the sleeper. with a mattress size of 76 x 25 inches. all other aspects of the regs should be fine... yes no??? thank you in advance.
a. dimensions .. 76 x 25 with a height of 40 inches
b. shape rectangular
c. access unhindered
d. location within cargo area and compartmentalized
e.exit from birth no center console, (more that 18 x 36 to drivers
f. com with driver N/A but more than adequate
e. equpment 8 in thick fire resist foam mattress & bedding
g.ventilation 4 windows
h. exhaust no more risk than drivers seat for fumes
i.Occupant restraint could install if necessary, no team 1 driver?
21 - 31 of 31 Posts
