I have a 00 6spd and my clutch pedal position switch is broken so my cruise doesnt work. I like being able to start the truck w/o having to get in and push the clutch, but i want my cruise back. Is there a way to put a jumper wire or somthing to get my cruise back w/o getting a new switch? If there is which wires do you connect/jump?
· Administrator
By the time you mess around putting on a jumper, you're better off replacing the switch. The safety aspect is a definite reason why you shouldn't jumper things like the starter lockout/cruise disable on the clutch switch. :nono:
What if you (inadvertently) or someone else starts your truck in gear and it runs over someone. That would be bad.
In all the years i have had my truck i have never started it in gear. That is just something i do not worry about. I am the only one who drives my truck, so if someone else were driving it they would have stolen it. My 70 GTO doesnt have a safty switch either and i have been driving it since i was in high school and have never ran over anyone. So, does anyone know which of the two wires control the cruise and which control the clutch saftey switch?
· Administrator
Well, they wouldn't let you run either car or truck at our local dragstrip. :shrug03:
Pins 3 and 4 are for cruise disable.
The provider of this information assumes no liability for the misuse of this information.
