1 - 9 of 9 Posts
So I bought an Auto Enginuity Ford package and tried doing a CCT. It said that it would give a report and any low cylinders would be shown in the form of a trouble code. However it just said test completed and never showed me anything about results. I have seen pictures of what people have done before with their trucks but I don't know how to access the results.
Also I installed a fuel pressure gauge last night. When I accelerate hard I can get my fuel pressure to drop from 60psi down to 40. (measured on the passenger port by the bowl drain lever.) If I accelerate normal it doesn't drop any or if any more than maybe 2 psi. Is this more likely a weak pump or a plugged fuel filter?
I know the truck has another small pump installed before the factory one so I'm not sure whether or not the factory one is any good. I think the second one may have been installed to fix a "low pressure" situation but is merely a bandaid not a fix.
My pump pressure does not drop below 65 psi on acceleration either. I don't think that is a bad thing. Maybe you have a properly working pump.
The CCT will only return codes if there is an issue. If there are no problems, it just reports "test completeted" - I don't get any error codes either - and I don't want too...
Have you done the Hutch mod? You may have a moderate obstruction in the tank screens that doesn't affect it until you really push it.
Unless somebody installed a second pump, you only have the one on the framerail. Dropping down to 40 isn't the greatest, but I wouldn't replace the pump because of it. If I remember right, it's still in spec. I will have to check.
As for the CCT test, evidently you don't have any issues to trigger a code. If you want to see the actual numbers, go to the second tab (live data meter) and select a cylinder in each box. The last box can be used for rpm. You can go to the graph if you wish. I suggest checking out Woodnthings guide to AE. Rt has the link.
Fuel system mods I have done:
Baldwin spin on fuel filter (BF7587?) before the pumps
Drilled my banjo-bolts in the heads to flow more fuel
Removed the safety device from the fuel filter bowl
Where do I find the woodnthings guide?
Bookmarks - better than sliced bread...
Discussion Starter · #9 ·
Thanks guys. I'll be sure to read through that entire thing. Even bookmarked it. Woodnthings sure has put alot of time into going through stuff like that. I really appreciate it when people enable the do-it-your-selfers to do more!
1 - 9 of 9 Posts
