I hear what you are saying, although the the electronic end is probably the easy part. That is, P transducers, a board to collect and analyze them and then display them is no harder than the monitor-based performance systems (e.g., Edge Monitor), but where I am uncertain is in accessing the CP's. I guess you'd have to tap each cylinder, which in porinciple should work, but over time, I would be worried about it fouling the transducer (or path to it) and eventually, springing a leak. Then if one cylinder weeps, it may not be pulling its load and thus create an imbalance, etc. For bench testing, no big deal, but for a permanent install, big deal.
Ralph
