Need pics of this. I am assuming all you do is tap the rubber line before the pump, and run it into the Dahl, then back to the pump?
Pics are very helpful!
Can someone post more information on the fittings that have smoother curves than a 90º bend? Photos, specs, part numbers, etc.Some have found better fittings for the Dahl filter than Bob Riley provides in order to avoid the 90º bend before and after the filter.
If you are talking about the Torx bolts coming from the seats through the floor pan, they are nearly perfect and the holes on the mounting bracket need minor elongation. That is where my filter has resided for nearly 6 years. No problems. The best way to do this would be to replace the torx bolts with longer ones to get a bit more thread to hold the bracket on. Mine have been held on with locktite and a narrow locking nut. The torx have an unusually fine thread. I think it is like a M22x1.75 or something like that.Can someone post more information on the fittings that have smoother curves than a 90º bend? Photos, specs, part numbers, etc.
I plan on doing the intake modification from ITP. I also have the Dahl 100. I haven't done it yet, but the Dahl and truck seem to have a perfect bolt pattern match behind the transfer case. I think I just need to widen the holes on the bracket, and purchase 2 nuts. Hope it works out this easily.
I just confirmed that the nut will not have enough threads on the bolt. So now I'm trying to understand Torx bolts and which bolts are the ones to do something with.If you are talking about the Torx bolts coming from the seats through the floor pan, they are nearly perfect and the holes on the mounting bracket need minor elongation. That is where my filter has resided for nearly 6 years. No problems. The best way to do this would be to replace the torx bolts with longer ones to get a bit more thread to hold the bracket on. Mine have been held on with locktite and a narrow locking nut. The torx have an unusually fine thread. I think it is like a M22x1.75 or something like that.
See the red colored comments.I just confirmed that the nut will not have enough threads on the bolt. So now I'm trying to understand Torx bolts and which bolts are the ones to do something with. They hold the seats in.
Where can I buy longer Torx bolts? What size?Go to Fastenal with one of the bolts and get one a cm longer.
Can the Torx bolts extend further by tightening them down? Doubt it or the seats would be loose. I'm not sure how these bolts work, but I notice there's some extra bolt length at the top where they bolt to the seat.
What tool/size do I need to remove the Torx bolts (E6, E7, E8, E10, E12, E14, E16...just looked at Sears online)?T55+ bit or driver.
Mine do not look anything like that.:shrug03:Here's what my seat bolt looks like. It is possible that I'm working with the wrong seat bolt.
From the photo, you can see I have a torx and I have a hex nut. This is why I though I could adjust the length of the bolt. I loosened the hex nut, and this did not loosen the bolt. I think the hex nut is for the seat, and the torx for the bolt.
I thought the "T" torx bit was for the male, and the "E" torx for the female?
